SimScale CAE Forum
Meshing takes too long . Fails at the end
I am trying to create a mesh around a building with HVAC equipment. When I tried to the meshing initially, it failed after 398 mins.
Is there any way to do it quickly?.
Hi @aa49khan!
Please share the project with us here in the comments so that we can have a look at your setup.
Thanks for the reply jousefm.
Please let me know if you can view the project or not.
https://www.simscale.com/projects/aa49khan/hvac_work/
Abrar Khan
Hi Abrar!
Could you simplify the model beforehand or remove at least the loosely parts disconnected from your main component? If you do not have a clean geometry and then simply run a mesh on it which might do the job is not something I would really recommend.
Feel free to reach out to me once that is done and I will help you out!
