Here is my project url: https://www.simscale.com/workbench/?pid=1273627186663416156&mi=spec%3A281f2c4a-879a-497a-a052-fa1c8ddac2e3%2Cservice%3AMESHING%2Cstrategy%3A35&sh=34
Hello Team ,
I need help meshing my geometry. My attempts to mesh my geometry all failed or didn’t generate any faces after a long time. I was trying to mesh with hex-dominant and standard. When I tried the standard approach the log told my to check edge refinement, I couldn’t find any information about this and wasn’t sure what to change. The hex approach was way better, but it took a really long time and failed right at the end after wasting many core hours. So when I was trying to optimize my standard meshing attempt I tried custom sizing to fit the faces to my channel width, I tried surface refinement on the curved faces of my model, I played with the smallest feature surpression, I tried to first have a look at a small section of my geometry. But neither of those things helped with my meshing. I would really appreciate if you could help my find a solution for it. I try to simulate airflow through my channels with a porous membrane under it. If you need further info please contact me!
Dear Tom
