Meshing error
Run 2
  • Velocity field started diverging to a value of 1.10082e+07 m/s near the position: (27.09, 26.69, -2.818). Please check the mesh quality near the reported location and try refining the mesh. If the problem occurred near a boundary, please check the boundary conditions. In case of doubt, please ask for assistance via our support chat.
Hi @upasse
I had a look at the project link you gave but unfortunately, I cannot access it. Could you please enable Share with support so I can take a closer look at your setup and simulation logs?
A diverging velocity field typically indicates numerical instability, often caused by poor mesh quality, geometric artifacts, or unsuitable boundary conditions.
In the meantime, I would recommend checking the following:
  1. Locate the divergence: Check the run event log for the coordinates where the divergence occurs. You can use these to inspect the affected region in the viewer.
  2. Check the mesh quality: Look for distorted cells, small geometric features, or problematic boundary layers near the divergence location. Consider adding local mesh refinements if necessary.
  3. Review the boundary conditions: Make sure your boundary conditions are consistent, particularly near inlets and outlets. If the divergence occurs near these boundaries, consider extending the flow domain to reduce their influence.
You may also find this forum discussion helpful.
Once you have enabled Share with support, I would be happy to investigate further.
Thanks!
Bryan
