Hello
I have a meshing error taking me to the fatal IO page.
The simulation is at
I increased the small feature suppression to 1e-4m and now the meshing log says as below. Can anyone help?
Model import took 1h6m6.625355432s.
Maximum precision of model and its entities: 6e-07 m.
Absolute small feature tolerance: 0.0001 m.
Gap refinement size is reaching lower cell size cap for 13 faces in region . Consider lowering model tolerance if resulting mesh fineness is too coarse.
Gap refinement size is reaching lower cell size cap for 463 faces in region [B3_TE5]. Consider lowering model tolerance if resulting mesh fineness is too coarse.
Gap refinement size is reaching lower cell size cap for 2 regions. Consider lowering model tolerance if resulting mesh fineness is too coarse.
Layer refinement was not applied on 6 faces because they were removed by small feature suppression, by the non-manifold boolean for conformal meshing or assigned as start/end faces in a sweep mesh refimenent.
Tim Kendall
