I just wanted to ask if Simscale has changed the meshing algorithm for ‘hex dominant parametric’ as the CADs I was able to mesh before are failing now. I have cleaned the CAD and there are no intersections. Can you please tell the what change has been done so that we can change our CADs accordingly. The results do not converge using the Standard mesher. This issue is being faced by many FS teams so I request to please look into it and if possible revert back to the previous meshing algorithm.
Hello crabbit,
thanks for reaching out to us.
Can you please share a link to your project with us,
so that I can have a look at the CAD file.
I’ll also reach out to the Meshing team to check weather they have changed something that might cause your issues.
Hello crabbit,
thanks for sharing the project with us.
I’m currently working on a solution.
You said that using the standard mesher is not an option, because the simulation does not converge.
Can you please also share this simulation project with us as I would like to understand why it’s not converging?
