Project Link: https://www.simscale.com/workbench?publiclink=297ebd1e-65d6-4490-9a59-7b4cb22118a6
Hello!
i’m trying to achieve a fluid Simulation with heat exchange with a range of solids (Conjugate heat Transfer). The CAD data consists of 14 solids, one of which is the volume of the fluid.
The Simulation should be a transient, turbulent flow Simulation. with the complete structure at an initial temperature and the fluid and air surrounding it coling it down.
I’m unsure which parameters i should introduce to the mesh for it to create the Interface zones between the fluid and the solids.
I tried Mesh Refinements but after a mesh run it didn’t create the cell Zones i was expecting for the geometry and it keeps showing the mesh quality checker failed.
The geometry of the Project is the following: The solid 13 is the fluid volume and the solids 0 to 12 are the steel plates and glue layers i’m aiming to cool down.
The Parameters for the fluid Zone i chose are:
and for the solids:
I’d like to know which procedure i should follow or which other settings i should use for the solver to create the surfaces i Need for the Simulation to use as Interfaces.
Thank you
