Hello, I have made a box mesh refinement with max. length 1 cm and otherwise all default values. Now the max aspect ratio has shot up to > 1e4 and I can’t find the bad elements(s). Can anyone tell me where, I can usually see them (for other meshes) but not here.
Update: using a cutting plane I can find some cells which are white with “no result” if I inspect them.
Maybe these are the real problem.
I still can’t find the bad cell, is the rest of the mesh ok? Where there is colour I can see only blue, unless I select region 2 in which case every outline goes red anyway.
More importantly I don’t follow the solution. Doesn’t everything have to be solid? I uploaded from onshape then fixed the interferences and made a boolean union of everything in simscale’s own CAD, following the docs. I checked for small gaps. Is there something odd in the CAD at this point? I might try increasing the small feature suppression (slightly) if there is.
I can’t get that box labelled volumes:1 that’s in your screenshot.
