Hello, everyone!
For the past few weeks, I have been trying to conduct a mesh convergence study for a static structural analysis, but I have been facing some problems. The simulation link is here: https://www.simscale.com/workbench/?pid=2633001207437297647
What happens is that my mesh does not seem to be converging on single value. Initially, I was trying to refine the mesh for the whole model, but it did not work. I thought that maybe this result was because the greatest tension gradient is located at a stress concentration spot. Then, I proceeded to refine my mesh just in this location, using the Region Refinement tool. However, the results that I have so far, do not seem to converge as well. I am using the strain value to acess the result, as this is the most important parameter in this case. The results I have so far are (element number / region refinement max. edge lenght / max. strain):
296k - 0.0002 - 2.387e-2
657.9k - 0.0005 - 2.866e-2
730.7k - 0.00045 - 2.865e-2
867.6k - 0.0004 - 3.05e-2
1.1M - 0.00035 - 3.165e-2
Could I have some guidance here? I am confused if I am doing some pre-processing step wrong or if my mesh simply just did not converge yet. I think the my case is not very complex, so I would expect the results to converge with less than or a little more than one million elements. The material I am using is ABS, which with that amount of strain would not behave as a linear material, and maybe that is the reason for the divergence, but I am not sure if this would have some impact in the values, once I stated for the software that it is a linear case.
I would really appreciate a help! Thank you so much!
