Material Law on Liquid Bulk Modulus
My configuration is Multi-purpose, steady-state, Compressible OFF, Constant gas mass fraction cavitation, using liquid nitrous oxide.
I need implementation-specific confirmation of:
  1. The liquid density equation, including the meaning of Liquid bulk modulus coefficient.
  2. Whether the entered Density is evaluated at Liquid reference pressure.
  3. Whether Liquid bulk modulus should be isothermal or isentropic.
  4. Whether the pressure-outlet input and the Pressure solution field use gauge or absolute pressure in this exact configuration, and what datum is used.
My liquid density and isothermal bulk modulus were evaluated at 293.15 K and 5.0525 MPa absolute. Should that pressure be entered as Liquid reference pressure?
The initial-condition field is labeled “Absolute static pressure,” while the cavitation validation example labels its outlet pressure as gauge. Please clarify which convention applies to each field.
