I was successful in simulating my project, but didn’t get the expected results. So I changed a part of the CAD Model, but now it won’t mesh anymore. Eventhough the main part of the model remained the same. Only a small part changed (actually got smaller than before) so that I hopefully can get the right heat values for my simulation.
Now I am not sure what I have to do, it doesn’t matter how I select the finesse of the mesh, it always fails. It also fails when I let the mesh create “autmoatically” by just starting the run of the simulation.
Any tipps here would be much appreciated, as I seem to be completely stuck ![]()
Here is the mesh log:
Model import took 2.667379614s.
Maximum precision of model and its entities: 1e-06 m.
Absolute small feature tolerance: 8.033298707211546e-06 m.
Number of faces after 5m0.000119103s: 0
Number of faces after 10m0.000157306s: 0
Number of faces after 15m0.000178674s: 0
Number of faces after 20m0.000140754s: 0
Number of faces after 25m0.043101091s: 1567749
Number of faces after 30m0.000194185s: 2980648
Number of faces after 35m0.000174129s: 2980648
Number of faces after 40m0.000159589s: 2980648
Number of faces after 45m0.00014879s: 2980734
Number of faces after 50m0.000146927s: 2980734
Number of faces after 55m0.000118062s: 2980734
Number of faces after 1h0m0.000122157s: 2980734
Number of faces after 1h5m0.000150973s: 2980734
Number of faces after 1h10m0.058306269s: 2980734
Number of faces after 1h15m0.090901809s: 2980734
Number of faces after 1h20m0.000143122s: 2980734
Number of faces after 1h25m0.00014186s: 2980734
Number of faces after 1h30m0.053442081s: 2980734
Number of faces after 1h35m0.006081245s: 2980734
Number of faces after 1h40m0.040352876s: 2980734
Number of faces after 1h45m0.003355086s: 2542441
Number of faces after 1h50m0.099397808s: 3668944
Surface meshing took 1h54m54.496853795s.
Here the link to the project: Link to project
Thanks for your help.
Mav
