What you are trying to achieve
I am trying to simulate Hydrogen flow in a pipeline
An description of what is happening:
After I press the run button, I saw the error
Detected divergence of the linear system solver.
Consider lowering the relaxation factor for field k.
What I tried:
- Refine the mest (Increase the coarse-fine handler to 8.0)
- Check with the mesh log (The worse metrics is max non-orthorgonal: 73)
- Lower relaxation factor of k to 0.01
The error still persists.
Hi, could you expand a little more on the setup & physics that you have? What are the objectives of this study?
The pressure at the inlet is incredibly high, which is generating velocities >>> 10000 m/s. Are you sure about the boundary conditions?
Thank you Ricardo, I followed your suggestion and the next error occurs
Gauge pressure field started diverging. Gauge pressure = -1.88025e+22 at position: (0.02149 m, -0.003365 m, 0.5389 m).
I wanted to look at the mesh at this position, but could not find out how to do it from Standard Mesher | Meshing for CAE | Documentation | SimScale
