Hi
In this assembly, the toggle clamp is supposed to move down the upper large disk on the Z axis to compress two rubber disks.
But it doesn’t matter where I apply the force, upper disk won’t move down enough to touch rubber disks and put pressure on them.
If they don’t touch each other, there is no resistance against the clamp. Therefore, there shouldn’t be any stress on it. However, the simulation shows stress in many parts but negligible movement in the Z axis.
Where is my mistake? Did I choose the right type of analysis? Is there an issue with the contacts or boundary conditions?
