Job Status not updating?
I’ve noticed a few times, that I’ll start a mesh job and the Job Status window will say “Starting…” but never update. If I refresh the screen, then it shows that it was complete. Anybody else notice this? I did have multiple tabs/projects open at the same time, could this be an issue?
Hello @fastwayjim,
thank you for giving the feedback! You also found the correct correlation in that case. Right now the job updates will only appear consistently in your last “project tab”. We are going to make this work consistently also for multiple tabs as 1. a lot of users work with multiple projects opened and 2. it allows you to compare your settings with other benchmark cases, but for the time, unfortunately, you need to refresh.
Best Alex
Good to know, thanks!
