I uploaded the mode from Fusion360 using Add-in.
Though, the SimScale complines about two Invalid geometries pointing to the two edges. Geometry table is listing the faces and these no matching numbers either.
How I can find what are those faulty edges?
Hey @jpnurro,
please, post a link to your project.
Kai
The simulation item in the question:
Hey @jpnurro,
sorry, i cant also find this edges
Your geometry is very complex, if you like to simulate the cooling fan, maybe you can reduce and simlify your geometry.
Kai
Hi Kai,
I did cut all unnecessary stuff away but still I get two edges error (now new version with Edge 40&42 )
BUT, saving the file as STL in the Fusion360 and uploading that seems to work
Though, it complains about the holes in the faces. After running the STL with Netfall correction the scaling is way off (even using mm). Rescaling with 0.001 fixed that.
The next problem is that the Flow extraction volume-Open Inner region is not available after the fixing the STL
BR, JP
