I am trying to create an internal flow volume where the inlet and outlet are formed by concentric tubes, ie, air enters a small diameter tube, and exits via larger tube which surrounds the small one. No matter which seed face I pick, I always get an error with message ‘Please select a Seed face adjacent to the desired void region.’ This is for a tesla pump, inverse of a tesla turbine, SimScale
Hi there, thank you for using the forum!
I have a couple of questions:
What kind of analysis do you wish to perform?
Can you include a screenshot that shows where the flow region, inlets and outlets are located?
You can see the inner tube entering, and outer tube surrounding it coming out. I have shown the two boundary faces and seed face. I also tried the inner tube wall as a seed face and get the same error.
Analysis initially is incompressible flow. Once I have that working I also want to use the same geometry for conjugate heat transfer simulation.
To me this seems to be one edge case where the internal flow region operation doesn’t work, because the shaft volumes (which has a boundary) protrudes through the second boundary.
So it would be best to obtain the flow volume directly in your CAD tool - it should be fairly easy with an extrude operation to create a “raw” flow region:
And then you can simply use boolean/subtract operations to obtain the flow region.
The result should be a geometry with 2 volumes: a flow region and a rotating zone.
