Import CAD model as 1 solid, with surface for apply the pressure (see drone )
I saw in the course “drone design workshop” in exercise 2 where you perform structural analysis, that in the upper element to shape the contact surface of the bolts there is a region inside the surface without creating 2 solids. There is no difference in height, is in the same plan.
How do I create a surface inside a face to apply a load or increase size mesh, as in the example? In the file used in onshape, I can’t understand what tool to use in CAD because the entire part is imported.
I use autodesk inventor for modeling: I tried with surfaces for resolve this issue, but during the mesh phase ignores the surface.
Can you help me?
Thanks simscale team
Hi @ErmoB, I remember doing that workshop and I know what you mean. Is there a face-splitting tool in Autodesk? All that has happened is they have split the large face to allow for more accurate refinement.
Let me know how it goes,
Darren
Hi @ErmoB & @1318980!
I think @ahmedhussain18 created a GIF long time ago on how to split models in Onshape. You can use the search function of the forum to find it. If you cannot find it I will post the link later on.
Edit (Useful links):
Here is the splitting operation; Partition Parts - #2 by ahmedhussain18
Ahmed
thank you to everyone for the indications, they were helpful. With inventor I found the tool, if it can serve someone:
3D Model tab -> Modify panel -> Split to split a part into multiple bodies
In the feature dialog box, click Split Face
Best
Ermo
