For automatic you can specify the initial values. The values will change throughout the simulation (it’s dynamic).
The mesh in your project has a decent number of cells in error (30) and volume ratio is also kind of high (127 max). You can use the newly added mesh quality visualization feature to try and spot these bad cells & locally improve mesh quality.
And you can also switch back to manual relaxation any time, in the Numerics tab.
