How to use 3D image data for Fluid flow simulation on SIMSCALE
I have a stack of tiff images of rock core sample scanned using X-ray microtomography instrument. I want to do fluid flow simulation using the Lattice Boltzmann method. Can anyone explain workflow for fluid flow simulation on 3D image data using LBM on SimScale?
Hi @ashahi!
Using a scanned object would probably work however the LBM module can only be accessed with the professional license.
All the best!
Hi @jousefm,
I have an academic license.
However, can you elaborate on the process and workflow for fluid flow simulation using SIMSCALE on the scanned object? I may think of obtaining a professional license.
In which format are you importing your geometry? Try using meshlab to get a STL out of your scan: https://www.meshlab.net/
