Hi, I’m Aiden
I want to see how the heat spreads by shooting light at the glass, and I don’t know how to make light source in projects
thank you
Hi, I’m Aiden
thank you
Hi Aiden, this is Fillia
Tell me a little more about your project, what analysis type are you using? It would also be nice if you can share it here, so I can have a look.
There is no such setting as a ‘light source’ but adding a heat source could be a workaround, what do you think? What specification do you have regarding this light source?
hi fillia, this is Aiden
First, it consists of glass, die, and pcb substrates. I wanted to see the spread of heat after shooting light on a glass display. but there is no source of light. so I asked that question.
thank you
Aiden
No problem, you can always add your feedback for this feature here: https://roadmap.simscale.com/tabs/2-under-consideration?_ga=2.101094405.521483523.1611518044-2084675998.1596445923
