How to setup simulation for peripheral outlet vacuum motor
I am trying to measure static pressure or total vacuum pressure of my vacuum motor but I don’t know what to run or how to set it up.
should I run incompressible or compressible and if so how do I set it up because I cannot seem to find specific tutorials on this and the simscale forums and tutorials are very broad and don’t help me.
Project Url: https: https://www.simscale.com/workbench/?pid=4569703002705308592&location=simulationSnapshot:3dbfa379-a311-49e9-8ee6-f04281ea742a
Hi @liamstrickland9, welcome to the forum!
To answer your first question about whether to run an incompressible or compressible simulation for your vacuum motor: you should generally start with an Incompressible simulation. Unless the air velocity inside the motor exceeds Mach 0.3 (roughly 100 m/s) or the density changes by more than 5-10%, an incompressible solver will be much more stable, solve faster, and provide accurate pressure readings for standard vacuum applications.
Here is the general workflow to set this up:
  1. Flow Volume Extraction: Since you are simulating the air inside the motor, make sure you extract the internal fluid volume from your CAD model. You will be meshing the air, not the solid motor parts.
  2. Rotating Region (MRF): Vacuum motors require a rotating zone around the impeller. You need to create a cylinder that encloses the blades and assign it to an Advanced Concept → Rotating Zone (MRF). Set your rotational speed (rad/s or RPM) here.
  3. Boundary Conditions:
    • Inlet: Set this to a Pressure Inlet at 0 Pa (gauge pressure), assuming it is pulling air from a standard room.
    • Outlet: Set this to a Volumetric Flow Rate or Velocity Outlet if you know the flow rate you want to test. Alternatively, if you want to find the “dead head” maximum vacuum pressure, you can set the outlet flow to near zero.
  4. Measuring the Pressure: To get the exact static and total pressure readings you are looking for, go to Result Control → Surface Data. Add an “Area average” item and select the inlet and outlet faces. Once the simulation finishes, this will give you a clean plot of the pressure generated by the motor.
ok thanks I was running compressible sims and getting lots of divergence.
I also am confused about the exclusion of the rotation zone from the flow volume and what its suppose to look like as well as how to prepare the rotation zone because the forum tutorials on this are outdated and not very clear.
How does putting the outlet velocity near zero give me the max static pressure at the inlet? Wouldn’t making the outlet flow near zero also make the inlet velocity near zero and mess it up?
Glad the switch to incompressible helped avoid the divergence! Let me clear up the confusion on both points:
1. Preparing the Rotation Zone (MRF) You don’t actually “exclude” the rotation zone from the flow volume. Instead, the rotation zone must be created as a separate solid body within your CAD software.
  • How to prep it: In your CAD tool, model a simple cylinder that completely encloses the spinning impeller blades but does NOT touch the outer motor casing.
  • When you import the model into SimScale, you should have at least two fluid volumes: the main air volume, and this cylindrical MRF volume.
  • In the simulation setup, you define the materials for both as air, but then you go to Advanced Concepts → Rotating Zones, select that cylindrical body, and give it your RPM. The solver will then treat the fluid inside that specific cylinder as if it is being rotated by the blades.
2. The Zero Velocity / Max Pressure Concept You are entirely correct that making the outlet flow near zero will also make the inlet velocity near zero—but it won’t “mess it up.” This is exactly how you find the maximum static pressure of a fan or pump, known in the industry as the “shut-off head” or “deadhead” pressure.
  • The Physics: Even though the air isn’t flowing through the motor, the impeller is still spinning. The blades are constantly hitting the trapped air and throwing it outward via centrifugal force.
  • Because the air has nowhere to exit, it piles up and compresses against the outer casing. This builds up the maximum possible static pressure the motor can generate. Once you allow air to flow (increasing velocity), the static pressure will drop.
If you want to map out the real performance of the motor, you usually run 3 or 4 simulations at different flow rates (e.g., 0%, 50%, and 100% of the max expected flow) to create a standard Fan Performance Curve.
