Help with meshing
Hi everyone!
So I have been experimenting with SimScale for an academic project.
So far i read some white papers and tutorials. Right now I am following this one Incompressible Turbulent Flow Around a Spoiler | SimScale but for calculate lift and drag on a flying wing.
This is my mesh refinement region
global seetings
And this is my model exprted from Fusion360
How it looks for you guys? Seems a long processing time for just the mesh, did I do something wrong?
Thanks for all the help I received so far
Hey @lcolonna
Please post the Project link so other users can take a look and possibly help out!
Dan
My bad
https://www.simscale.com/projects/lcolonna/resposta_de_asa_voadora_para_agricultura/
Here it goes
Hey @lcolonna
It was a bit confusing to see what happened but i think you set the mesh to internal. So your mesh was applied to the inside of the geometry in your enclosure.
You need to switch this to External
When you change mesh settings for any reason, Simscale gives you a new estimate. This estimate would be way to much for what you need but i find that the estimation seems to be over exaggerated. Always start with a coarse mesh and refine higher based on what you need, so shoot for 1-2 million cells at first with external and post the results.
Dan
