I want to investigate the deformation at the pin and the pin mounting areas. I am new to this and I am having difficulties setting up the right BCs as well as contacts. I appreciate any suggestion/idea.
Thank you,
I had a look at your model. Initially you can do the following:
Bond the thumb screw and clamp arm via bonded contact.
Bond the Clamp body and lock pin via bonded contact.
Apply a penalty physical contact between Lock pin and clamp arm with stiffness value of 1e12.
Apply fixation to the bottom of your clamp body.
Apply the force to the desired face. You also have to apply an elastic support with somehow a value of 500 to 1000 to the top face of the thumb screw in order to resist rigid body motion. Due to this, make sure that ‘stop if singular’ under ‘Numerics’ is turned false.
I hope this will work. On the other hand due to your clamp being different on both sides, you can take the symmetry otherwise I would go for it.
Also consider removing the small faces from your model. You have 3 under clamp arm along face where the force is applied and others are over screw head. Furthermore, use tetrahedral with local refinements and only refine the contact faces in order to make you mesh size small.
