Handling bolted joint connections in structural FEA — bonded contact vs. modeling real preload?
I’m analyzing a bolted assembly and trying to decide how much detail the bolted connections actually need for a trustworthy structural result. The simplifications range from very crude to very expensive, and I’d like to hear how others draw the line.
The options I’m weighing:
  • Bonded/rigid connections — fast and stable, but they ignore slip, separation, and the real load path through the joint. Fine for a rough stiffness check, but I’m unsure how far to trust the stresses.
  • Simplified bolt representations (beam or spring elements with preload) — a middle ground, but how well does this capture the clamped region and load transfer?
  • Full contact with modeled preload — most realistic, captures separation and slip, but expensive and can be tricky to converge.
A few questions:
  • For a general strength/stiffness assessment, when is bonded contact “good enough” and when does it seriously mislead?
  • When you do model preload, how are you applying it, and does it change your results meaningfully vs. the simplified approach?
  • Any practical tips for getting contact-based bolted joints to converge without blowing up solve time?
Trying to match the modeling effort to what the result actually needs, rather than over-modeling every bolt.
It depends on your specific case. For example, if you are looking to study the bolts/immediate surroundings or if you are worried that the bolts might fail, it wouldn’t make sense to greatly simplify the bolts.
But if the bolts are just there to transfer the load from one part to another and your regions of interest are far, you won’t gain much from capturing them as accurately as possible. See e.g. the Saint-Venant’s Principle.
