Hi!
You should go back to your CAD and fix the errors, for example:
- Bad surfaces
- Intersecting parts
- Small gaps
- Bad export of the STEP file
On the panel at the right you can see the problems with the model. If you select one, the problematic entities are highlighted.
Thanks!
