I’m getting the below error when I upload the geometery, kindly help.
BR
Glenn
BR
Glenn
Hi Glenn! Would it be possible that you try to upload it as a step file instead of iges?
Hello Tsite,
I did, but I’m getting two errors:
I want to create multiple flow regions using open inner region, but I can only create one . When I select the other flow region to be created, the seed face selects the entire entity and cannot select boundary face.
The contacts are unpopulated.
here is a snip for your better understanding,
This is what I’m supposed to select:
But this is what im getting ( the entire region is turning into seed face instead of only the hole)
Any update here?
BR
Glenn
Hi Glenn, I hope you had a nice weekend
Keep in mind that stl files are not suitable for this type of analysis. Try to use .step instead.
Hello Fillia
I did! hope you had a good weekend as well!
I tired, getting the same error
