- For my master thesis I am trying to simulate the airtightness measuring of a high-rise building with a Fan pressurization (Blowerdoor). A blowerdoor creates a pressure difference across the building envelope and I want to see the pressure through the building.
- How do I get presentable results for a script of presentation out of the simulation? Is it possible to see pressure loss in the building due to friction? And pressure difference due to a temprature difference between inside and outside of the building (stack effect)?
*https://www.simscale.com/workbench/?pid=1498623906592097814&mi=spec%3A9345bce4-2bb2-4fbd-899a-ac8f3bfff210%2Cservice%3ASIMULATION%2Cstrategy%3A15&ps=analysis%2FCompressible--oneOf%2FboundaryConditions%2F4
Hi there, thank you for using the forum!
The Post processor can be used to visualize the pressure inside the flow value, however, it is not possible to distinguish “different” types of pressure. If you have a formula, you can download the results and use Paraview’s calculator locally.
If anyone else has some recommendations regarding this, feel free to share.
