Extract the result from the first analysis
I need to be perform a shell analysis with different thickness and different BC.Let us assume the thickness is 1 mm then i need to apply the pressure of 0.5MPa, then i need to extract the results, After that i need to give a input of next case for this results then i modified the thickness 0.5. How to solve this problem.
Shell( 1mm thick)—> Solve----->Results-------> Shell( 0.5 mm thick)—> Solve----->Results
(Next analysis take a output from the previous analysis)
Hello @duraisamy,
I just want to point out that Simscale currently does not support Shell elements. Depending on your overall geometry size you might be able to use a second order 3D tetrahedral mesh.
Christopher
