Hello
My rotational simulation fails to generate the external volume, it says any reason.
Please help me to figure out the problem, and make the external volume to continue the simulation.
Thank you
Best, Kim
Hello
Thank you
Best, Kim
Hello Kim,
Seems like it’s because some of the faces are not forming a continious loop while generating the flow volume such as this one.
Applying one click Imprint operation should do the trick by splitting faces in contact accordingly. Then flow volume operation should be successful.
Hope this is helpful,
Kaan.
Super, it worked perfectly. THAK YOU!
