How can I extend the runtime of a completed simulation that hasn’t fully converged yet? say from 1500 to 3000s,
Also a related question: how can I produce a force report on objects also after simulation completion? I forgot one item in the result control setup.
Hi @Naly,
in Simulation Control, increase the number in the field End time value [s] and if necessary increase the Maximum runtime [s].
You need to define the Result Control Items \underline{\text{prior}} to the simulation.
Hope I could help here.
Hi
Thanks for your quick reply.
If I increase the simulation run time and start, wouldn’t that reset the entire simulation? What I meant to ask was is there a way to continue the simulation for an extended 1500s?
As for the forces plot, do you happen to know if that’s doable on paraview?
Hi @Naly,
Yes it would but that is inevitable. You would have to restart the simulation.
And in general:
In case you already ran the simulation and have not assigned the Result control item, you can also compute some data within Paraview.
As an inspiration, please have a look at this blog post:
https://blog.simscale.com/blog/2014/07/aerodynamics-post-processing/
Thanks for your help
