nope it didnt help.
maybe you can spot problem here?
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 2.3.1 |
| \ / A nd | Web: www.OpenFOAM.org |
| \/ M anipulation | |
Build : 2.3.1-262087cdf8db
Exec : simpleFoam -parallel
Date : Oct 14 2018
Time : 07:44:37
Host : “”
PID : 150
Case :
nProcs : 16
Slaves :
15
“.151”
“.152”
“.153”
“.154”
“.155”
“.156”
“.157”
“.158”
“.159”
“.160”
“.161”
“.162”
“.163”
“.164”
“.165”
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Reading/calculating face flux field phi
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555555555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Creating finite volume options from “system/fvOptions”
SIMPLE: convergence criteria
field U tolerance 1e-05
field "p." tolerance 1e-05
field k tolerance 1e-05
field omega tolerance 1e-05
Starting time loop
–> FOAM Warning :
From function writeOldTimesOnSignalFunctionObject::writeOldTimesOnSignalFunctionObject
in file misc/writeOldTimesOnSignal/writeOldTimesOnSignal.C at line 84
‘writeCurrent’ was set. This may lead to uncaught segmentation faults
–> FOAM Warning :
in file misc/writeOldTimesOnSignal/writeOldTimesOnSignal.C at line 105
sigTERM unset. Setting it to true so that signal is propagated to other processors
If this is undesired explicitly set ‘sigTERM false;’ in “system/controlDict.functions.sigHandler”
[0] Set SIGFPE(8) signal handler
To switch this off set ‘sigFPE false;’
[0] Set SIGSEGV(11) signal handler
To switch this off set ‘sigSEGV false;’
To catch Ctrl-C set ‘sigINT true;’
[0] Set SIGTERM(15) signal handler
[0] Set SIGQUIT(3) signal handler
To catch the USR1-signal set ‘sigUSR1 true;’
To catch the USR2-signal set ‘sigUSR2 true;’
4 signal handlers installed
[1] Set SIGFPE(8) signal handler
[1] Set SIGSEGV(11) signal handler
[1] Set SIGTERM(15) signal handler
[1] Set SIGQUIT(3) signal handler
[2] Set SIGFPE(8) signal handler
[2] Set SIGSEGV(11) signal handler
[2] Set SIGTERM(15) signal handler
[2] Set SIGQUIT(3) signal handler
[3] Set SIGFPE(8) signal handler
[3] Set SIGSEGV(11) signal handler
[3] Set SIGTERM(15) signal handler
[3] Set SIGQUIT(3) signal handler
[5] Set SIGFPE(8) signal handler
[5] Set SIGSEGV(11) signal handler
[5] Set SIGTERM(15) signal handler
[5] Set SIGQUIT(3) signal handler
[6] Set SIGFPE(8) signal handler
[6] Set SIGSEGV(11) signal handler
[6] Set SIGTERM(15) signal handler
[6] Set SIGQUIT(3) signal handler
[9] Set SIGFPE(8) signal handler
[9] Set SIGSEGV(11) signal handler
[9] Set SIGTERM(15) signal handler
[9] Set SIGQUIT(3) signal handler
[12] Set SIGFPE(8) signal handler
[12] Set SIGSEGV(11) signal handler
[12] Set SIGTERM(15) signal handler
[12] Set SIGQUIT(3) signal handler
[13] Set SIGFPE(8) signal handler
[13] Set SIGSEGV(11) signal handler
[13] Set SIGTERM(15) signal handler
[13] Set SIGQUIT(3) signal handler
[14] Set SIGFPE(8) signal handler
[14] Set SIGSEGV(11) signal handler
[14] Set SIGTERM(15) signal handler
[14] Set SIGQUIT(3) signal handler
[15] Set SIGFPE(8) signal handler
[15] Set SIGSEGV(11) signal handler
[15] Set SIGTERM(15) signal handler
[15] Set SIGQUIT(3) signal handler
[4] Set SIGFPE(8) signal handler
[4] Set SIGSEGV(11) signal handler
[4] Set SIGTERM(15) signal handler
[4] Set SIGQUIT(3) signal handler
[7] Set SIGFPE(8) signal handler
[7] Set SIGSEGV(11) signal handler
[7] Set SIGTERM(15) signal handler
[7] Set SIGQUIT(3) signal handler
[8] Set SIGFPE(8) signal handler
[8] Set SIGSEGV(11) signal handler
[8] Set SIGTERM(15) signal handler
[8] Set SIGQUIT(3) signal handler
[10] Set SIGFPE(8) signal handler
[10] Set SIGSEGV(11) signal handler
[10] Set SIGTERM(15) signal handler
[10] Set SIGQUIT(3) signal handler
[11] Set SIGFPE(8) signal handler
[11] Set SIGSEGV(11) signal handler
[11] Set SIGTERM(15) signal handler
[11] Set SIGQUIT(3) signal handler
forces forces10:
Not including porosity effects
forces forces11:
forces forces12:
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0.023856188765, Final residual = 0.000109506282281, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.0248066097167, Final residual = 0.000241574964413, No Iterations 5
smoothSolver: Solving for Uz, Initial residual = 0.0212609155836, Final residual = 0.000100702670271, No Iterations 6
GAMG: Solving for p, Initial residual = 1, Final residual = 0.00960066015176, No Iterations 8
