I am running incompressible fluid projects and keep getting this error message. I went back to projects I have done previously that ran successfully and ran them again and got the same error message. Is this server related?
[0] → FOAM FATAL IO ERROR: (openfoam-2012)
[0] Entry ‘pFinal’ not found in dictionary “system/fvSolution.solvers”
[0]
[0]
[0] file: system/fvSolution.solvers at line 9 to 24.
[0]
[0] From const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&, Foam::keyType::option) const
[0] in file db/dictionary/dictionary.C at line 537.
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[b4d014642d84:00001] PMIX ERROR: UNREACHABLE in file …/…/…/src/server/pmix_server.c at line 2193
[b4d014642d84:00001] 7 more processes have sent help message help-mpi-api.txt / mpi-abort
[b4d014642d84:00001] Set MCA parameter “orte_base_help_aggregate” to 0 to see all help / error messages
