Hi, I’ve been trying to get a dynamic simulation of my assembly built in Onshape, It is difficult for me to understand the way to create a simulation that give me a von mises graphic because it’s always blue all the piece, and it doesn’t matter how many faces i select, the result is always the same.
I made a last try with a static simulation but i can’t run it because i got this suggestion
“Your analysis does not contain a sufficient set of constraints and would likely fail. Please review your simulation setup before starting the analysis and make sure your model is sufficiently constrained by boundary conditions.”
when i define the “fixed support” condition in two volumes of my piece, i got another suggestion
Ill thank a lot any help you could give me, i have just a few days to abtain the result of the Von Mises graphic, and i
m not sure about what to do for getting it.
This is the project’s link
