I am trying to download a mesh I created in simscale for use with Salome locally. Some forums responses mention downloading meshes as a .med file, but every time I download the mesh, it’s downloaded as an OpenFOAM “constant” folder. How do I change the download format?
Thanks,
Hi @andizam!
There is no dedicated option to choose which mesh file type you want to download. So you would need to convert the polyMesh with a tool or using OpenFOAM command lines or simply import the unmeshed geometry to Salome and mesh it there if that’s okay for you.
