Dear community,
I’ve built a simulation of an air conditioner in an office:
https://www.simscale.com/projects/Sternin/ventilation_of_the_workplace1/
Within the scope of post-processing I want to identify the heat flow rate from a warm surface “human skin” into the room interior (air).
In the simulation setup I used the Analysis Type “Natural convective heat transfer” defining a constant temperature for the skin surface.
For post-processing I’m using the ParaView-Tool. I’ve already identified the relevant surfaces. Now I just need to know which tool I have to use in order to determine the energy transfer [W] (heat flow) from these surfaces into the air. Of course heat flux [W/m²] values would be acceptable too.
Thanks in advance
Andrew
