When I create the mesh, the solid inside the mesh doesnt appear. Why is happening this?
Hey @jz_rate,
your base mesh box that defines the flow domain around your geometry for an external aerodynamics mesh does not contain the geometry. See the image below. You need to adjust the coordinates of the minimum and maximum point of the box to fit to your model, then you are fine with your setup!
Best Alex
But actually when I place the geometry in the mesh it still doesnt appear.
