Convert Facet to Advanced Geometry
I am looking to conduct thermal analysis on a Lunar Rover model. It is a solidwork assembly. I am looking to run conjugate heat transfer v2.0 because it can simulate heat radiation. However, it said that it is unavailable for facet geometry and I need to reimport it. How would i convert it to advanced geometry?
Link to project: https://www.simscale.com/projects/duybui04/scarce/
Hello duybui04,
Are you possibly using a ‘.stl’ file upon import?
Please refer to this forum post:
Best Regards,
Satvik from SimScale
No, it’s a .sldasm file. which is the assembly file from solidworks
Hi @duybui04
In my evaluation, that may be due to the sub-assemblies present in your folder:
A workaround for that is provided here.
Please tell me if that solves the issue :slight_smile:
I technically already did that (the zip file name is the same the main assembly name). But i will go ahead and try again. In the mean time, are there any other solution you can provide? I think its because of the cad file itself but I’m not quite sure how to fix that
Thanks!
