Hi
I’m new to Simscale. I’m trying to do conjugate heat transfer analysis on a battery pack. For some reason, when I run imprint, no contacts are being generated. I need to make the thermal model of the battery pack. As there are no contacts, I can’t run the simulation. The link to the project is given below -
The model is made using Solidworks and was imported as an assembly file as per the requirements.
When I tried the same simulation with just the cells alone ( by removing the cell holders), there are no errors. Imprint works fine. But I need to get it done with the cell holders.
Thanks in advance for any help.
