I am working on the temperature distribution on solar panel with fin as cooling system under a forced air convection. I had a problem with my post-result because the temperature on a solar panel seems to be weird. I think, my simulation set up might be a problem.
Here is my simulation set up details;
Inlet Velocity = 0.5m/s
Ambient Temperature = 30c
Heat flux = 50 W (power sources (panel))
Hi again, I took a quick look at the document you sent. It seems that the images above that you want to recreate are the results without cooling ( this means it is a design different than yours , without fins).
I made some changes to get closer to the test case you want to recreate here:
I set the ambient temperature at 26.85 like in the paper (from 0 degrees)
I deleted the silicon part and replaced the source with a heat flux wall boundary condition at the top surface with a value of 600 W/m^2 as the paper indicates
What about the fluid properties? Did you use the same as in the paper?
