I am trying a thermal simulation. But when I try to set up the geomerty, both Conjugate heat transfer, Conjugate heat transfer 2.0 are greyed out, I tried a different CAD in the same file/simulation, and it has those cases ready, once I get my old model, It greys out again.
What might be the issue here?
Hi, could you please post a link (URL) to your Workbench, so we can have a look at the project?
On a side note, this usually occurs for one of the reasons below:
- The geometry is a .stl file (which is not supported for CHT simulations)
- The model contains a single volume. Note that CHT requires at least two volumes in the geometry, since we are simulating both fluid and solid regions. For more notes, please check this page.
https://www.simscale.com/projects/ChetanGowda/battery_anaylsis/
This is my project. I’m trying to simulate a battery pack but yea, I guess the reason for my failure was that I had one solid region with me, I thought, I’d distribute the whole heat output from the batteries evenly.
Now I’m thinking that I should model all the batteries seperately and provide individual heat outputs for all of them.
Thank you so much for your help Mr.Ricardo. Hope you have a Great Day
