Condensation simulation
Hi all,
I am trying to create a condensation/decondensation simulation. I created a simulation using Conjugate Heat Transfer v2.0 that should reproduce this phenomenon. The relative humidity value on the surface is 100%, but is it possible to check how much moisture has condensed on the surface? Does anyone have a workflow for this kind of request?
If not, can I manually import a model or result to check this?
This result is crucial for me, as it will help me to identify the critical areas.
Thanks in advance!!
Hey @jaat0003 ,
Phase change simulation is not yet possible within SimScale. So there would not be any other examples that you can import either to check this kind of a simulation.
Let us know if you have more questions :slight_smile:
Satvik
