Coefficient of drag over a cylinder
Hello!
I’ve running what I thought would be a relatively simple simulation to find the coefficient of drag over cylinder at different Re numbers (linked here). I’m calculating the coefficient manually: summing the viscous and pressure forces in the flow direction (-Z in the simulations) to find the drag force, and dividing by 1/2 (density)(v^2)(D x L) to get the coefficient. For moderate Re = 10^4 or 10^5, the results seem OK, if not as accurate as I was hoping: I’m getting about 0.85, when published values are closer to 1.1. However, when I get down to Re=100 or less, the coefficient explodes: at Re=100, I get a coefficient of 23.7 (vs. about 2 in published numbers), and it gets worse at lower Re values. I’ve worked on adding mesh layers around the surface (15 layers that probably equate to 2 normal layers, with a y+ value well below one). In all other ways, the simulations seem to make physical sense, and they’re not particularly complicated.
The 2 simulations on this project are named by their Reynolds number.
Any ideas why I might be getting these values? I feel like I must be missing something obvious, but can’t figure it out. Thanks for any help!
Mike
