Hi SimScale community,
I’m a student working on a project called Project ARCTIS — a simplified magnetocaloric refrigeration system using a Halbach array and a Gadolinium (Gd) magnetocaloric bed. I’m trying to run a Conjugate Heat Transfer IBM simulation to generate a temperature distribution heat map across the assembly for a student research submission.
System description:
Closed loop fluid system — water circulates continuously through a serpentine channel inside the Gd bed, through connecting stub pipes, through heat exchanger channels, and back through a curved return pipe
No true inlet or outlet — the loop is continuous
Solid bodies: Gadolinium bed, Copper HX plates, Aluminium housing, Steel pipes
Fluid: Water
What I’m trying to achieve: Show heat transfer from the Gd bed surface (fixed at 295.93 K) into the circulating water and through the surrounding solid assembly — producing a colour heat map showing temperature distribution across all components.
What I have successfully done:
Uploaded STEP file from Fusion 360
Selected CHT IBM as simulation type
Successfully extracted Internal Flow Volume — SimScale correctly detected the entire connected fluid path as one body
Assigned materials to all solid bodies
Set Fixed Temperature boundary condition on Gd bed surface (295.93 K)
Set gravity, initial conditions, numerics and simulation control
Generated mesh and obtained a result using stagnant water
The core problem: Because my system is a closed loop, I cannot use velocity inlet and pressure outlet boundary conditions — SimScale flags the faces as internal and ignores them. I want to simulate forced flow at approximately 0.2 m/s to show realistic heat transport from the Gd bed into the water and through the pipes, rather than just conductive diffusion from stagnant water.
What I have tried:
Pipe split to create open ends for inlet/outlet — SimScale still flags faces as internal
Average Velocity momentum source across entire flow volume — uncertain about direction for complex serpentine geometry with multiple flow directions
Fan momentum source — same problem with direction for complex geometry
My specific questions:
What is the correct SimScale approach for forced flow in a closed loop CHT simulation?
Is momentum source the right tool, and if so how should direction be configured for a multi-directional serpentine geometry?
Is there a better simulation type for this specific case that still captures fluid-solid heat transfer across the full assembly?
Thank you in advance.
