Hi all, I’m running a steady CHT v2 study of a generic e-machine with a helical water-glycol jacket. Project is public: “MGU-K CHT study, rotor-bearing heat path”.
Setup
– Fluid: ρ 1060 kg/m³, cp 3400 J/kgK, ν 3.302e-6 m²/s, Pr 29.75 (k-ω SST, incompressible, steady)
– Inlet: mass flow 0.1413 kg/s, 40 °C. Outlet: pressure 0 Pa
– 4 absolute power sources in solids: 2000 / 200 / 40 / 40 W (total 2280 W). All other external walls adiabatic.
Expected: T_out = 40 + 2280 / (0.1413 · 3400) = 44.7 °C
Result: T_out = 76 °C (ΔT ≈ 36 K, i.e. ≈ 17 kW absorbed by the coolant)
What I already checked
- Power sources in downloaded case (fvOptions):
volumeMode absolute, one cellZone each (region2/3/6/7). Coolant is region4, no source there. - Mass flow confirmed by area-averaged inlet/outlet velocity (2.66 / 2.73 m/s through Ø8 mm).
- Same result on two meshes (14.4 M and 4.1 M cells), with and without non-orthogonal correctors.
- Changing solid cp (450 → 4500) gives an identical T_out curve.
- Initial T = 40 °C, inlet T = 40 °C verified.
constant/region4/transportPropertiescontains nu, rhoRef, Pr, Prt — no Cp.- Solver log: continuity errors “sum local” ≈ 0.01 per iteration, T residual stalls at ~8e-5.
Since the coolant cannot absorb more than the 2280 W injected in steady state, this looks like the fluid ρ·cp not being applied as expected in the solid–fluid coupling. Is there a setting I’m missing, or is this a known issue? Thanks!
