CHT fatal I/O error
I have encountered a fatal I/O error during my last simulation in which i tried to simulate a transient CHT problem SimScale
This is only the second time i ran this kind of a problem so i am probably missing something but still i would like some help regarding how to deal with this error.
i made sure that there is the proper amount of interfaces during meshing, and this error occurs on two separate models i have meshed.
Any suggestion would be welcomed,
Thank you,
Rotem
Hi @RotemL!
I will have a look at your project asap and get back to you as soon as I identified the error source.
From what i could figure out this has something to do with the timestep, once i shortened the timestep or set to adjustable timestep the simulation started running, very slowly but at least now its running.
Thanks,
Rotem
Hi @RotemL and thanks for letting us know!
Glad you figured it out by yourself :slight_smile: Keep us up-to-date and make sure to add some nice post-processing results under your project!
All the best!
