Changing Analysis from Static to dynamic without re-building model again
Is it possible to change the static analysis to a frequency response and then a dynamic analysis without starting the model from scratch every time?
Hi there, this is Fillia :slight_smile:
I understand that it is manual work, but the simulation has to be set from scratch indeed. Make sure to add your feedback regarding this here: https://roadmap.simscale.com/tabs/2-under-consideration?_ga=2.101094405.521483523.1611518044-2084675998.1596445923
Thank you Fillia. Much appreciated. How much will it be to upgrade my membership? Also, does membership allow me to use a more enhanced SIMSCALE or is it the same as I am currently using?
Kind regards
Raf
