CFD Temperature Field Divergence
I am trying to to perform CFD on an aircraft, looking at pressure changes around the aircraft.
Temperature field started diverging error on each run. I believe my mesh is fine enough and that my setup is correct but I am not fully sure as I am new to CFD.
Any help would be appreciated. I tried to use a template from someone elses work but still no luck.
Hi there, have you checked this forum post? Temperature field started diverging even when mesh is refined - #11 by ggiraldof
Let me know what you think :slight_smile:
Excellent thankyou, I will give that all a go now.
