Is there a step by step tutorial on how to simulate a rotating marine propeller.
@anon62721193 simulated a while ago a propeller - find the public project here: SimScale
You can make a copy of it and change your CAD model upstream to make use of the already existing mesh and simulation setup.
David
Thanks David I will give it a go
All the best
Mark
the most important part is that your CAD model does not just contain the propeller itself but also the part defining the rotating region around it. From then on you can reuse the meshing and simulation setup of @anon62721193.
David
