Hello, I am trying out the software and over the course of following along with the centrifugal pump tutorial I have run into an issue the causing the simulation to fail. It appears to be a meshing quality issue, but am unsure of how to correct this issue without straying from the instructions. Could I get a second set of eyes to guide me on the solution to this issue? Thanks!
It appears that the simulation run in your project has been deleted, but I would advise you to revise the simulation setup.
E.g. the velocity inlet condition is not the same as the tutorial’s:
The tutorial uses 8.5e-3, not 8500.
Hi Ricardo,
Thank you for the correction. I will give that a try and re-run the simulation. If the issue persists I will update you here.
Thanks!
