Dear All,
I am trying to reproduce the centrifugal pump tutorial. The description is here: Fluid Flow Through Centrifugal Pump | Tutorial | Simscale
I did all as described and started the simulation. The created project is here: SimScale
The problem is that the results those I have got are not the same as in tutorial. For instance I have inlet pressure 62 kPa instead of -35.7 kPa but the velocity direction looks correct. Axial thrust is close: -388 N vs. -362. The torque is different: -10.2 Nm vs. -7.4 Nm.
Could you help me to find the errors?
