Project link, the title is pretty self explainatory. Whether i try to create a new sim run or delete an old one, it does not work. Just hangs with the “working” animation.
EDIT: additonaly, cant access anything related to previously done sim runs (Solver log, convergence plots, solution fields).
Sorry to hear you are experiencing some issues. Could you try it again? For me it works now. If it does not work, SimScale is probably running a maintenance so this is probably the reason behind it. They should resolve it shortly.
Hello, yes it was due to server maintenance which quite frankly is happening regularly for the last 2 days from 11 to 13 h CET. It also started again as i’m writing this. I hope you don’t plan on making this a regular thing.
